Configures the offset value to be used for the ISID/NSI mapping over VLANs with no associated NSI mapping. When this value is configured, tagged VLANs with no associated ISID/NSI mappings are applied with an ISID/NSI value of (configured offset value + VLAN tag value).
isid-nsi-offset | Specifies Individual/Network Service Identifier offset applied on the Client/Proxy for VLANs with no ISID/NSI mapping. |
isid_nsi_offset | Specifies the ISID/NSI offset value. Range is 0,16773121. |
none | No ISID/NSI offset value needs to be applied for VLANs with no ISID/NSI mapping. (Default). |
Unless configured, there is no ISID/NSI offset value by default.
This command is only used when operating as a Fabric Attach Client/Proxy. It has no effect when operating as a Server/Standalone Proxy.
The following example enables ISID/NSI offset of 2000:
# configure fabric attach isid-nsi-offset 2000
This command was first available in version 33.1.1.
